How to convert number into words pl SQL code?
Hello experts,
How to convert number into words Pl SQL code? And if there is no application that can convert this can you give me another way of converting this through programming languages? I think there are some ways that a programming language can possibly help me regarding this matter. Show me some solution guys.
Thank you.
Best Answer by talki rathy
Answered By 0 points N/A #173541
Actually there is, it was written by Brenton Fletcher using PHP codes. You input the numbers and it will print it in words. It can convert numbers to words up to decillion.
You can test the script online, or you can copy the codes at http://bloople.net/num2text/.
Nelson
Answered By 0 points N/A #173542
Hi Green,
Here I have given the code to solve your problem. You can know about this by visiting the following link http://www.orafaq.com/node/1448. Hope this will give you the best solution.
Please refer attachment.
