How to Convert HTML Files To Pdf and Psd Format
I have been trying to convert some Web pages to PDF and Psd format. I have tried to use the screenshot from the Windows, but the size of the document is get small then the actual one and it doesn't look clear.
Beside that the process is little slow because  i have to screen shot does not allow to convert the file in to PDF and Psd format directly.
Would like to know to what is the best way to that?
Best Answer by billphp
Answered By 0 points N/A #129025
Convert HTML pages into PDF with just one click:
Create web pages or html file into PDF documents is as easier as ABCD, Just with a single click. There are two way to create PDF file one of them is “Adobe Acrobat X Pro” & “Nuance PDF Creator” like software lets easily turn HTML pages into PDF files. When using Microsoft Internet Explorer or Firefox in Windows.
Just clicking once to convert a web page to a PDF with all formatting and links intact.
Another way to convert HTML pages into PDF  is some website.
Just with a single click you create PDF file, that are https://pdfcrowd.com:443/  & http://www.pdfonfly.com  like website tools lets easily convert HTML pages into PDF files.
Answered By 0 points N/A #129026
Hello good day!
I have here a link to convert HTML to PDF just click this and below follow the instructions Download Link.
If still you couldn't convert your file by using this link to try to ask for a software for html converter.
