How to convert bmp to wmv vbnet?
Hello experts,
How to convert BMP to wmv vbnet?
There are some instances that I cannot get a free converter online for there are shareware versions only but now I hope those converters are now available as a freeware over the internet.
I hope you can also guide me on the proper installation process.
Thank you.
Answered By 15 points N/A #179665
Hi
Here, you are seeking help for converting a set of bmp files to wmv.
You are trying to do so but because of lacking the technique, you are failing to get the video file.
I think some good tutorials and help manuals can help you solving this problem.
This is good for doing. So, see how you can convert bmp to wmv from these links:
Use some programming codes to make the convert easier. Here is the link:
You can use c# coding for that purpose. This link may help:
May all this makes a good helping blend for you.
