How to convert avi to wmv library files?
Good day to all.
My question is how to convert avi to wmv library files?
What do I need for this easy conversion?
What steps can you recommend that is easy to do?
Please include a brief overview of this conversion as well as its system requirements.
I'll be looking forward for your answers.
Best Answer by Floyd Pitcock
Answered By 0 points N/A #139309
Hi Ruthprobertson
A free software that will enable you to convert video files from AVI to WMV is WinX Free AVI to WMV Converter With this free software, user(s) could also support extracting images from AVI video to save as JPEG and BMP.
The good thing about this software is that it's Hyper-threading technology supported, this means it has fast speed. Furthermore, it enables you to convert more than one video at a time and it 's :
  • 100% Free
  • No Spyware
  • No Malware
  • No Adware
  • No Viruses.
Answered By 0 points N/A #139310
Hello
To convert successfully from AVI to WMV you need to download WM converter 2.0 which is popularly known with conversion of AVI files. You can download it using this link; After being installed to your computer, open it and choose Input files.
With the application file selector, choose the AVI file you want to convert. Select the Other Formats and take WMV format which is what you require and further click to convert on the conversion button.
The avi will then be converted and saved as an original WMV extension file.
Or you can better still use the online method with ZamZar.com. Everything is on the site.
I don’t think you will be having any problem there.
Answered By 0 points N/A #139311
Steps to Convert AVI to WMV Using MediaConverter.org
Step 1 – Launch your computer’s web browser and navigate to the Media Converter website.
Step 2 – Click the “Upload a File” menu link located approximately half-way down the web page.
Step 3 – Select the “Choose File” menu button and use the website’s file chooser to pick the AVI file to convert to WMV format.
Step 4 – Choose “WMV” as the output video format for the file conversion.
Step 5 – Select the “Start” menu button to initiate the file conversion process.
Step 6 – After file conversion is completed, select the “Download Link” to download the converted file to your computer.
Steps to Convert AVI to WMV Using ZamZar.com
Step 1 – Launch your computer’s web browser and then open the ZamZar website.
Step 2 – Select the “Choose File” menu button and select the “AVI” file using the website’s file chooser.
Step 3 – Choose “WMV” as the desired file output from the video conversion and enter a valid email address.
Step 4 – Click the “Convert” menu button and the ZamZar website will send an email with a link to download the converted file.
