How to convert 3gp to mpeg video formats.
Hi experts,
I am using a Nokia symbian mobile, the videos generated by it are in 3gp format and I am not able to play those videos on my system. Is there any software or online tool through which I can convert 3gp to mpeg video format.
Answered By 5 points N/A #164748
Download Super Software from this link: http://www.softpedia.com/get/Multimedia/Video/Encoders-Converter-DIVX-Related/SUPER.shtml This software is multimedia player and converter also. You can convert your 3GP files in MPEG with it. Open your 3GP file and drag&drop to the grey field at the bottom. Now Select the output container for setting the container as MPG. Press ctrl + T for launching Output File Saving Management. Here you can choose where to save your MPEG file and click on Save Changes. Finally click on Encode Active Files to start MPEG conversion.
Also you can use online converters who are free and easy such as ZamZar : http://www.zamzar.com/ Here with four simple steps you will convert your files from 3GP to MPEG. Fist choose your 3GP file then choose in what format you want to save, next enter your email address and click on the button Convert. After converting you will get your converted file on your email.
Williamson Mellisa
