How to connect laptop with VGA to TV with HDMI
Hello! I want to watch movies from my laptop on my TV so i needed to find VGA – HDMI cable. I bought VGA – HDMI adapter that was in the MAC section (I don't know why), but when I put everything together I still couldn't make it work. My laptop detects the second screen, but usually when I used to do it with VGA – VGA cable my desktop was shown on TV, this time TV screen was black and I couldn't change it. Please assist.
Answered By 0 points N/A #173440
Assuming the adapter works (VGA to HDMI isn't very reliable), it's possible that your new TV doesn't support the resolution that is coming from the laptop — or the adapter doesn't support the resolution. Because you've used external monitors in the past, I assume you know about Fn-F5 to activate your laptop's VGA output.
Many HDTV's do have a VGA port already, but I guess yours doesn't…?
Check the specifications of the adapter and the TV, and make sure the resolutions all the way across are supported.
