How to change wireless program chinese iPhone?
Hi to everyone,
How to change wireless program chinese iphone? My cousin’s iphone default language was changed in to Chinese and I need to setup my wireless connection but I can’t find for it is on a Chinese language form. I really need your help to set it back to English language. We cannot use the phone because of this mistake.
Thank you.
Answered By 0 points N/A #183260
Hi Lindsay Wendy,
It is really a problem when our phones default language changes to an unknown language. I can suggest you two things to solve this problem.
1. Take another device of same model. Go to the settings and see the options in default language and see how to change it. Then take the first phone and try to change the language according to the ways of the second phone. I think it will be easy for you.
2. If it fails try to find "restore factory setting" alone or seeing options of another mobile of same model and give command of restore factory setting.
Good Luck
