How to change video format using pinnacle tvcenter pro software?
Hi to every one.  I like tv shows, dramas and other material like this and I have installed pinnacle tvcenter pro latest version to record them permanently. But I am facing problems as I try to convert video format from Divx to MPEG. I am using windows plate-form  and I am unable o find option how to convert/change format. Some guidance is required how to do this please.
Answered By 35 points N/A #141004
Hi there,
You don't need to convert the video format from divx to mpeg4. You can set pinnacle tvcenter pro to record your tvshows in MPEG format. You can do this by opening up the settings panel at the top left of your Pinnacle tvcenter pro screen and select the capture option to choose the recording formats. Choose MPEG4 in the top box on the right hand side and choose a preset, DONE!
