How to change the “Time History” from my firefox (Mozilla)?
I want to change the "Time History" from my Firefox (Mozilla). Now it keeps history for only a week and I want to keep record for the last months. What should I change to do that?
Thank you,
Eleni G.
Best Answer by George Stacy
Answered By 0 points N/A #126331
Hi Elenigmn,
You can set the number of days you want to remember the visited pages on Mozilla firefox.
Just open your browser, click on tools, click on options and then click on privacy. There you can see on the history “Remember visited pages for the last” ____ days. Edit the days you want or put 30 days for 1 month.
Unfortunately when you are now using Mozilla Firefox 4.0, this setting is no longer available.
Hope this information helps.
Answered By 0 points N/A #126332
hei elenigmn
this is easiest way to change the time history from mozilla firefox please follow the steps below If you type about:config in your address bar and then filter for history you'll find the entries browser.history_expire_days and browser.history_expire_days_min. Try setting those to 1 day.
thank's hope that helps
Answered By 5 points N/A #126333
It does not work in Firefox 4.0 because the support has been removed and Firefox will save it for 180 days by default. You should try in Firefox 3.6.16 because it still work, Click TOOL, then OPTION, choosing PRIVACY and changing the setting.
I recommended you to read this page: https://support.mozilla.org/en-US/questions/811524
Hope that it will help you a lot.
Answered By 0 points N/A #126334
To change time history from Firefox, follow the instructions below
1. Go to the options from tools, then select options.
2. From options, select privacy.
3. Then you will see a box named "history". From there "select use custom setting for history".
4. Then change the time period.
I think you will understand the process.
Good Luck.
