How to change Blackberry screen saver photo?
Hi Friends,
I am using BlackBerry Curve Smart Phone, in which I set a dark photo as screen saver, which made me difficult to read the icons. I would like to change blackberry screen saver photo. Please advise me in this regard. So that I can overcome this issue.
Thanks in Advance.
Best Answer by Hill Benda
Answered By 0 points N/A #142631
Well,
Everyone in the World uses the technology by customizing in his/her own way. In order to change screen saver on BlackBerry Curve smart phones, we need to follow following steps given in following list.
1. Press “Menu” button
2. Highlight “Media” icon then press TrackPad on Media Icon.
3. In Under Media icon, “Pictures” icon will be listed.
4. Select “Pictures” list and select the picture which needed to be set as ScreenSaver.
5. Press “Menu” key again on that picture and select “Save as wallpaper”.
Picture will be displayed as Screensaver.
6. Now press “End” Key to terminate the session and go to home screen.
Screen saver on your cell screen has been changed.
Answered By 0 points N/A #142632
To change screen saver on your blackberry curve Smartphone, you go to the menu, then to the media icon, then follow it up by pressing the track pad. Open the folder containing pictures and select the picture you want to save as your new screen saver. On selecting the picture, go to the menu key and select "save as wall paper" press end key to exit. That way you will have successfully changed your screen saver.
