How can you recover the data that’s on your hard drive?
Good day everyone!
My friend wants this advanced data recovery for my hard drive. And I don't know what's the process in recovering a certain data on the hard drives. So can anybody please help me in recovering my data. Thank You in advance.
Best Answer by Hodge Trafton
Answered By 20 points N/A #136317
Hello Aishley
Hope you will be fine.
By reading your post,i am now giving you some guideline of how to recover data.
(1) First download the software named(icare data recovery )from cnet.com.
(2) Install on your friends pc,run the software.
(3) Horizontal header will displayed.Click on quick data recovery.
(4) And then follow the directions.
This software gives you 90% result.
Thanx
Answered By 0 points N/A #136318
I think everyone has had this problem when he badly wants to get back data on pc.
I advise you before, to type “recovery” on your start menu bar; there is a way with windows to restart your pc on a date you choose before your data were deleted.
If nothing helps, i have many software that i can recommend you with like :
RECUVA
Or RESTORATION
Or PC INSPECTOR FILE RECOVERY
Good luck with that
Answered By 10 points N/A #136319
The common reasons why data cannot be open or why the hard disk will not function properly. First as you might accidentally delete it and the second is hard drive may suffer some form of failure.
There are several ways you can try to recover your data on your hard disk. You can try on your own or ask for help from the pros. Here are some ways or steps you can try:
  • Use Software you can find over the internet to recover your data. But there are things or steps you need to know in dealing with this software.
    1. Shut down the device  connected to your drive you deleted from then make a clone of the drive and try to attempt the recovery from the clone.
    2. Scan the clone file with different recovery programs.
  • Use different hardware to recover your data by figuring  out what component of the drive fail and the symptoms each failure cause.
You have to remember also any attempts to recover your data are risky. If the deleted or unrecover files are very important you must have to got to the professionals to seek help.
