How can import GPX flight simulator?
Hello, experts!
We know GPX flight simulator can automatically execute the "Metar Reader" program and search in the Internet for weather forecasts relating to a specific waypoint or the whole flight plan.
But, I want to know how can import GPX flight simulator?
Best Answer by Franklin Alejo
Answered By 10 points N/A #182569
Hi Robert,
As I understood your questions, you are looking for some application that will allow to import GPX Simulator to it.
So, here is link for downloading some applications:
If this is not what you are looking for, please specify what exactly you need, so I can find better solutions for your problem.
Best.
*links may not work after a few months
Answered By 0 points N/A #182570
Hi Robert,
You can try to import Microsoft Flight Simulator, which may be found on the official site of Microsoft support.
In case you already have a previous version installed on your PC, be careful to install the latest version, because in case you"downgrade" to an older version you may face one of the below issues:
  • Get errors that the operation is not supported by this PC
  • Filing of operation
  • The information retrieved might not be reliable.
So make sure you get the right version.
