No of visitors who read this post: 304
Category: MS Word
Type: Question
Author: Anonymous
Your rating: None Average: 4 (1 vote)
How can I work in Microsoft Word in a speedy mode. I am slow in writing. So what I should do for it?
Thank you.
Comment viewing options
# (Solution Accepted)
Hi Rahat,
Speeding up your writing skills can be explained in 3 paradigms.
  1. Mindset, a very well prepared work before starting to write.
  2. Typing skills. This will come on fly with experience, you can type more than 100 words per minute.
  3. Last one is the software that can help our work make faster, easier and accurate. Based on your problem, Microsoft Word has some features to make the work faster.
  • Turn on Auto correct option.
  • Check the Spelling and Grammar facility.
  • Use any third party software like Auto complete for Microsoft Word to make life easier.
Please let me know if you find any other solutions.
Cheers Aemmy
There are no system of mode in Microsoft Word that you can able to do accelerate your work within Microsoft Word. But there are some reasons why you want to work in a speedy mode. If you wish to do work in Microsoft Word you must go to the Control Panel and find quickly and set rightly the Ease of Access Centre.
There you will be find several options where you can see "Start on-screen Keyboard" options.
Click on Start on-screen Keyboard to active this on-screen keyboard you can do your work more easily with this kind of keyboard.
For typing in speed on MS Word, you must follow some rules and you can also use some software.
  1. You need to setup your fingers rightly on keyboard.
  2. You must setup your mind for type speedy.
  3. You can use some software for increase your typing skill.
  4. You must memorize all the key on keyboard.
Thank you.
