sushiman
110 points
Posted on - 04/24/2011
Is it possible to set my browser to never save any history on all the websites that I visit everyday? I want to do this automatically without having to click on the "Clear Browsing History" button. Any help?
fykes11
5 points
Set browser to never save browsing history
I'm using Opera as my default browser, this is a great browser for you can search the entire websites without saving your browsing history.
sushiman
110 points
May I know how it works, I'm currently using Internet Explorer as my default browser.
fykes11
5 points
Of course you will need the opera for you to use this feature. Just download the file in their site www.opera.com. Now when you installed it in your system, open the opera explorer, then you should see the uncheck menu bar (just tick on that so the menu bar will appear on the top of your browser). Then, go to file, and then select new private tab and that's it. You may now search anything without saving any browsing history.
sushiman
110 points
Do you have an alternative one for Internet Explorer?
I think IE has that feature also, Go to tools, then select in private browsing. To use this feature, you should have IE v8.
Hope this helps. Cheers!
Trevor
Most of higher version of internet browser today has the option of private browsing. Internet Explorer has this option as well as in Fire fox. But as far as the finger print or the mark of browsing, I am doing clearing the cookies and history. Whatever happened all your browsing history has gone.
Another solution for this is to set your browser settings to clear all browsing history after you exit your internet browser. On the next time the internet browser where used, no more history. All are clean.
Hope this helps and please be careful, most of the adult sites contains Trojans.
