How can I open iPhone eml file?
Hello experts,
How can I open iphone eml file? I got some eml file in my laptop and I send them all in my iphone mobile phone so that I would be able to know if I can open it through a mobile phone. But the error says unable to open file. What is the possible problem why I can’t open the file? I hope you can help me. Thank you.
Best Answer by San Ferrer
Answered By 0 points N/A #179220
Hello Madison,
Well. I get that, but that's only part of the issue. The attachments are not even displaying on the iPad or iPhone.  Normally, an unsupported file will come over and you click it and it says it's not supported. (.eml) files don't even show up.  I just tested this by sending phony (.junk) and (.zwr) attachments and the files are on the iOS device, just can't open them. There are third party apps I can load to read a (.eml) file.  But if the attachments are even getting to the devices, the application is useless.
Answered By 0 points N/A #179221
In Iphone and ipad you could not view attached EMLs.For this solution you need to install "EML File Reader".You can install this software from http://download.cnet.com/windows/.
After successful installation follow the following procedure
Step 1: Open the mail application
Step 2: open the attached file which you want to view
Step 3: Touched that file and hold your finger until a "menu pop up"
Step 4: click on the button “Open in EML file reader”
Now you can view the attached file
Answered By 0 points N/A #179222
Hi Madison!
I experienced your problem and I think you files in your laptop are not compatible to your iphone and its need to convert. You can have further information in this site https://www.techwalla.com/articles/how-to-open-eml-files . They have the procedure how to open files.
Thank You!
