I have got an ipad and I like to use different kinds of wallpaper. In this regard, ha retina wallpaper is my favorite one. If you kindly give me some links from where I can get new ipad hd retina wallpaper, I’ll be very pleased. I am waiting for your quick reply.
Thanks
How can I get new iPad hd retina wallpaper?
Elijah LawrenceÂ
Yes, the HD Retina wallpaper certainly does look amazing. You don't have to download the wallpaper itself, there is an Application available in the Apple Appstore, which can change and upload different wallpapers for you.
Please visit the following link to see how the application works, and then simply download it from the Appstore on your Ipad.Â
https://itunes.apple.com/za/app/amazing-wallpaper-hd/id386368383?mt=8
Hope this helps
You can get the Retina Wallpapers and High Definition Home Screen Backgrounds for your iPad from the itunes website. Just click on the link below:
https://itunes.apple.com/us/app/retina-wallpapers-hd-home/id384922950?mt=8
You can also search for this application using your iPad device. Just go to the iTunes store and search for it and then click Install. Ensure that you are running with iOS 4.3 or later.
