How can I get apple airport optimization via Bluetooth
Hello expert, I am using the Apple iPhone for some of my business purposes. I need now apple airport optimization via Bluetooth on my mobile? Please can you give me some guidelines to achieve my goal?
Best Answer by Drake Vivian
Answered By 5 points N/A #162339
These solutions may help you.
1. Try to connect to a 5 Gigahertz 802.11 wireless network instead of a 2.4 Gigahertz 802.11 wireless network.
2. When using AirPort base station, use the AirPort Admin Utility and select a different channel. When using third-party wireless network, check the documentation of the router device to know how to change its channel.
3. Check and see if potential sources of AirPort and wireless interferences.
4. Power off secondary connected Bluetooth devices.
Hope it helps.
Answered By 30 points N/A #162340
Hi there Kayla Spreckelmeyer,
There are no utilities that would do this for you, but you can try manually tweaking your AirPort to achieve the best performance.
The first thing you should do is to always connect to a 5 GHz 802.11 wireless network. To do so, open the radio mode and you will find those options there. Using the more options (by holding down the option button) you will get some more advanced options and choose "Use wide channels" there.
Another important thing is to always check if the wireless network you're connecting to is using a good speed-enhancement option. If not, unfortunately there is not much to do unless you have the access to the router.
You can also try temporarily disabling secondary or multiple devices connected via Bluetooth.
Best regards,
Drake Vivian
