How can I find my Asus Router IP
I have an Asus router. I connected it to my system and I try the default IP address 192.168.1.1 but was unable to open the setting. I install the other browser, but the problem is the same. I think that it is the Asus router fault, but before that I want to confirm it. I will be thankful if an expert can provide me any help.
Answered By 0 points N/A #186890
Hi Ronald,
Type 192.168.0.1/ in the address bar of the web browser and check if you can get into the settings of the router. It is not dependent on the type of the web browser.
Refer to the image for the web interface of the router for a similar configuration.
Anyet
Answered By 0 points N/A #186891
As default IP address for every route is 192.168.1.1. But it can be changed. As it looks like your Asus router IP address has been changed so you need to find the IP address of your router without that you cannot enter into the setting of your router. To find the IP address of your router Click on start type run and hit enter. In run type ipconfig/all and a new folder will be open which will contain the detail of your router ID address. Just enter that IP address on any browser and enter into the setting. Otherwise, you can also restore the Asus router and then your IP address will be changed to the default IP address.
