How can I export Mac Office Outlook Calendar to Excel 2011?
I am seeking help to export the calendar from Mac Office Outlook to Excel. Usually I am able to do this. But recently I have installed Windows Office 2007 and in this they added one more step which makes it is necessary to download to file and the comma separated value will convert to Excel. I have exported the calendar to Excel for sorting etc. and I am looking for help to how can be done this in Office 2011. We are using it for scheduling purposes and it is very important to us. The calendar listing can be shown but I am looking for how to invert the same to any other software.
Answered By 80 points N/A #93470
It is a very simple task, just follow the following steps.
1.Open Microsoft Outlook 2007
2.Click on "File," "Import and Export." The "Import and Export" wizard will begin.
3.Click "Export to a file" and click "Next."
4.Choose the file type to export it to. If you want to keep it in the regular Outlook format, choose "Personal Folder File (.pst)." To export it into another program like Excel, you can choose "Microsoft Excel 97-2003" or for Access "Microsoft Access 97-2003." For another program, choose one of the other options, such as comma-separated or tab-separated delimited file types. Click "Next."
5.Click "Calendar" in the next window. This will ensure that the calendar is what you are exporting. Click "Next."
6.Choose a location to export the calendar to by clicking "Browse." Click "Finish" once you are done to export the calendar to the location you specified.
If you need help with this contact us and we can help you out remotely.
