How can I download Lock-a-Folder Software?
Asked By 100 points N/A Posted on -
Hello experts,
How can I download the Lock-a-Folder Software? I need this to protect my files and data under my folder. I just want to protect all my files which is very important to me.
Your help will be much appreciated.
Thank you.
Best Answer by Maguiere Chuma
Answered By 0 points N/A #183956
I think that the Lock-a-folder software can solve your problem. It can lock and hide your folders from your PC.
Click the link below to download the software:
https://code.google.com/archive/p/lock-a-folder
Answered By 0 points N/A #183957
You can lock your folders, videos, images using a folder lock free software.You just need to provide a secure password to protect your files and drag the data to the security window.
The data will be hidden immediately from others. It's very simple and you don't need to be an expert for doing this.The download link is below:
Thank you.
Answered By 0 points N/A #183958
Hi Kathryn,
To protect your files, you must need Lock Folder 7 software. It is a complete tool for data security and protection of your files and folders. It can encrypt your files, lock, and able to secure back up. You can password protect your personal files and information to ensure no one can alter your most important files. And also, it protects and can trace in your computer in case of infiltration attempts.
Other added features on this software are auto protection for your files and application, Make Wallet wherein you can store personal information securely, and uses virtual keyboard. For free download of this software, just go to your web browser and type http://www.newsoftwares.net/folderlock/. Click on the free download, then a pop-up window will appear. Select Run. Complete the Set up Process. Then click install. Finished the process until it’s done.
Answered By 590495 points N/A #322527
If you want your folder to prompt you with a password every time you open it, the easiest way is to encrypt the folder. If you are using Windows XP Professional, here’s how to do it. Open Windows Explorer then navigate to the folder you want to encrypt. Next, right-click that folder and select “Properties”. In “General” tab in the Properties window, click “Advanced”.
In the “Advanced Attributes” dialog, under “Compress or Encrypt attributes” section, select or check “Encrypt contents to secure data” then click “OK” all throughout. And that’s it. The folder is now encrypted. Note: you will not be prompted for a password when you access the folder but other users will not have access to that encrypted folder.
On the other hand, if you really want to be prompted with a password when you open a folder, try installing LocK-A-FoLdeR. It supports Windows XP, Windows Vista, Windows 7, and Windows 8. Another one you can try to protect your folder with a password is Folder Lock. It supports Windows XP, Windows 7, Windows 8.x, and Windows 10.
