How can I clone my hard drive with different softwares.
One of my friends needs a hard drive so I am planning to give him. I want to clear all the data and it contains my personal information. How can I clone my hard drive?
Answered By 0 points N/A #99667
Cloning of a hard drive is a process of copying the content of one hard drive to another. I want to have a copy of the documents, files and folders. It is helpful when you loose the original one so you can also have a backup.
Step 1: Make backup of your files.
Step 2: Install the drive for cloning.
Step 3: Norton Ghost, HDClone are the cloning software that you can install.
Method 1- Use Norton Ghost
Step 4: Select the Ghost Advanced and then Clone button.
Step 5: Select your drives where you want to send your data and to which drive.
Step 6: Run your system and reboot it.
Step 7: Power boot your system after removing your hard drive.
Method 2- Use HDClone.
Step 4: Select your Source disk.
Step 5: Select From and To.
Step 6: Click on Start.
