reacraf
Posted on - 11/06/2013
I have few ADD-Ins in .xla extension which I need to add them permanently and any excel I open I want these add-ins to be visible. So I can use them easily and need to use them very offen
What are the steps to achieve this?
How can I add my ADD-ins in excel
You can add an Excel add-in through the following steps:
1. Navigate to File > Options > “Add-Ins” Category.
2. Under the Manage Tab, select Excel Add-ins, then Go.
3. This will open Add-Ins dialog box. Select the Add-In from the Add-Ins available box. Then, Click OK.
4. If you don’t find your Add-In available box, click Browse in the Add-Ins dialog box. Locate your Add-In and click OK.
