How can fix these errors so that Adobe Flash Player installs properly?
I’m currently using Windows XP with Service Pack 3. After I finish installing Adobe Flash Player, I receive an error message that says "http:/get.adobe.com/flashplayer/completion/aih/?exitcode=0 " followed by a second message stating "This file does not have a program associated with it for performing this action.
Create an association in the Folder Options control panel."
How can I fix these errors so that Adobe Flash Player installs properly?
Best Answer by jubayedjihan
Answered By 10 points N/A #138057
Hallo Maria,
You will need to check the file associations using the following procedure:
  • On your computer, go to start, and then click Control Panel.
  • After that click on Appearance and Themes, and then click Folder Options.
  • You will need to choose the File Types tab in the window that pops up, and after that you will need to find the extension that has a problem.
  • You will need to check for HTM, HTML as well as the Internet Shortcut.
  • For each of the above options, you will need to select and then click Change and then choose the desired program and the check the box that says "Always use the selected program to open this file type.
  • Click Ok after that.
Carl
Answered By 0 points N/A #138058
Try this link it will automatically indicate you about your current problems and your current version:
https://helpx.adobe.com/flash-player.html
First you should try to install a fresh flash player:
https://get.adobe.com/flashplayer/
For indication for a clean install:
https://forums.adobe.com/thread/928315
Click the Menu bar of browser>tools>option> content> Enable java script>apply>ok
Try downloading flash player using internet explorer because sometimes its show downloading error/problem with opera and Firefox.
Close all browsers and run the downloaded file.
Restart windows.
Delete remaining files in C:WindowsSystem32MacromedFlash
If you are using Internet Explorer 9, disable ActiveX Filtering.
  • Choose Start > Run.
  • Type firefox.exe -safe-mode and press Enter.
  • Click Continue in Safe Mode.
  • Click Tools > Add-ons. Disable all the extensions.
  • Start enabling the extensions one-by-one until you can reproduce the issue.
  • Temporarily Disable Your Anti-virus, Firewall And Anti-malware Programs
Answered By 0 points N/A #196488
Hi Dear,
This error is only the reason of bad state of your current flash player.
You have installed the older version of a flash player. The old versions are not supported with the latest browsers. Kindly download and install the flash player. You should use Adobe flash player 11.5. You can download it from this link.
It will help you to remove your problem.
