How to Cad model an iPod, Please provide me any example
I am studying Autocad, and have got an assignment to cad model an ipod. How to cad model an ipod, please provide me any example for reference.
Best Answer by Shifflett Laurel
Answered By 0 points N/A #193547
Hello
There is AutoCad version for iPhone but it works on iPad as well. It has all features as ordinary desktop AutoCad it is only redesigned to fit on smaller screens. You can easily open DWG, DWF, and DXF files and do your work as good as on desktop AutoCad. I posted link where you can download your copy.
https://itunes.apple.com/us/app/autocad-ws/id393149734?mt=8
Cheers.
Answered By 0 points N/A #193548
Hellow Greene Weaver,
Your want is most updated one in the IT world I am giving some outlines about this topics.
  • iPhone is now your hand canvas.
  • This gives us the opportunity to draw the live portrait.
  • The drawing canvas called “Drawing Now site” has the features as like AutoCAD in PC.
  • After creating a project you can access that drawing anywhere in the world via the iPhone or the iPod Touch (needs a WIFI connection).
  • You will be able to login to your account and browse all the files you have uploaded there.
  • You will be able to view all the sheets for the drawings.
  • You will be able to pan/zoom the drawing you are viewing, like you have been doing on the Drawings Now page.
  • For panning, you place your finger on the iPhone screen, and move your finger as if you are moving your drawing.
  • For zooming in or out, you need two finger slide. You need to place both your fingers together, and slide them up or down on the screen.
  • To get this new flair you have to download first the application from http://www.solidworks.com/sw/3d-cad-design-software.htm
  • Run the application next.
Thanking You
Shifflett Laurel
Answered By 0 points N/A #193549
Hi Greene Weaver,
The model of the front, back and side of the iPhone can be seen. Since, iPhone and iPod are of similar shape and size, this will help you model an iPod easily
Hope it helps.
