How to burn image across multiple disks?
Hello experts,
I am not familiar on how to perform any burning of files from one cd or DVD to another and I want to know if there are some applications or software that will allow a fast burning process so that it will not be time consuming anymore.
Thank you.
Best Answer by Smith Thompson
Answered By 5 points N/A #165822
Hello Young,
You need to  download CdBurnerXP a free cd/dvd burning software. This tool has an option of disk spanning which helps you to split your large data into multiple CD/DVD.
The download link is mentioned below:
https://cdburnerxp.se/en/download
Answered By 10 points N/A #165823
It is only possible if you are using multiple DVD write drives. You can take ones data and write it to the other one it is as easy as copying a file form one location to another location although you need to use DVD burner to do this. If you want to burn more than one DVD at a time it is also possible in this case.
Smith Thompson.
