How to boost volume pc 100?
Hello Experts,
How to boost volume PC 100? I don’t have any appliances such as a speaker that will probably get me into the mood with party rock songs. But I have an idea on how to boost volume PC 100? So that I will be able to use my personal computer when listening to my favorite music, is there a way that I can upgrade the HP Compaq laptop volume?
Thank you.
Best Answer by Laarni Hall
Answered By 25 points N/A #174738
Hello Jessica,
Good Day, Well, If you want to boost the volume of your songs without adding powerful speakers and etc, you can use software for that matter. I recommend VLC media player. It can play videos and audio files and almost all media files. More importantly, it can boost your movie or song's audio up to 400%.
You have to download and install VLC Player first. Check this site out:
If you already have VLC player installed, this is how to increase the volume up to 400%:
  1. Open VLC player.
  2. Load the video or song.
  3. Using your scroll wheel, scroll up until the volume goes to 400%. If you're still aren't contented,
  4. Click Tools > Effect and Filters.
  5. Check "Enable" and push the first slide bar to the Max level.
Hope this helps.
Answered By 0 points N/A #174739
The ‘Vlcplayer’ software has the ability to increase the volume of audio/video files up to 200%. I recommend you to use this for playing songs or videos. You can increase the PC sound in Win 7 OS.
For that all you have to do is abiding by the instructions.
