No of visitors who read this post: 210
Category: MS Word
Type: Question
No votes yet
I have seen in some word documents some pictures or texts are appearing on the back ground in a light color. It does not interrupt the main contains of the documents. I do not know what it is. Can anyone tell me what it is and how to add or remove it?
Comment viewing options
# (Solution Accepted)
I believe that you are talking about watermark option which is available in Microsoft word. I will take and example as follows in order to explain that. Please try to follow the below steps.
First open the document that you want to add a watermark. Then click on the page Layout tab and click on the watermark which is in page background section.
Now you can select either the available water mark in the each category or you can create own watermark.
If you want to add an available watermark, select it and click on it. I will add “confidential”.
Other wise you can create your own watermark by clicking “custom watermark”
Steps How to add background in Microsoft Word
1. Go to the Format menu and select Background.
2. Select Fill Effects in the Background window.
3. Select the Picture tab.
4. Click the Select Picture button.
5. Navigate to a picture file on your computer and click OK.
6. Click OK when the Fill Effects window returns and the picture you selected is in the Picture box and Sample box.
