Hibernate Button on Windows 7 Lost
20 points
Posted on - 03/31/2012
Why the hibernate button on windows 7 can be lost when I did not do weird things, how to restored it?
If You wan to enable hibernate in your windows 7, just follow bellows method :
At First Open a Elevated Command Prompt.
Then the elevated command prompt, type powercfg -h on and press Enter. (see screenshot below)
Now Close the elevated command prompt.
I hope your problem will be solved
You can solve your problem in two ways.
