Help using OCRAM in Bios
Hello!
Please help me with my problem.
After flash I cannot O C R A M to bus 1000(5 – 5 – 5 – 15). And system cannot POST.
Bios is getting auto restore to default. When I changed the setting to multiplier=2.xx, system was seemed stable.
With F6 function key, combo stay stable, FSB 1200 & RAM bus 1000 (5 – 5 – 5 – 15), V CORE DF, V DIMM+ 0.3.
Anyone have idea about this.
Thank you in advance…
Answered By 20 points N/A #100990
Hallo Gwean,
The BIOS should restoring its default settings automatically when you change the settings as mentioned in your question possibly because you have automatic configuration setting for the BIOS turned ON, and therefore you will need to turn it OFF.
You will need to access the BIOS and make sure that the settings for DRAM Auto, Time Selectable and Time Configuring are turned off, and in case you need to change the BIOS settings later you will have to do it manually so as to avoid the problem with the BIOS updating itself automatically.
Hope this helps.
__
Regards
Mahesh Babu
