No of visitors who read this post: 186
Category: Internet
Type: Question
Author: Anonymous
No votes yet
How do I solve the error “The application cannot find one of its required files, possibly because it was unable to create it in the folder. Please make sure that the folder in which this application was downloaded is accessible and not read-only.” I bought a license online but every time it tries unpacking the set up file I experience the same error.
Help
Comment viewing options
Hey Dear!
Do not worry about this problem. This error occurs when the setup files are corrupted. That is the reason you are facing this error. These files are not able to install Windows 7. The question here is, how to overcome this problem? The answer to this question is very simple. You just have to download the new working setup. When you will run the setup it will extract all the files that will work for you.
So, I just recommend you to download new setup. I hope it will help you in fixing this problem
Thanks
Tunacao Caaron
# (Solution Accepted)
This is most definitely a corrupted setup file. Have you downloaded this particular file?, if so then please check if it is compatible with Windows 7, since many executables normally made for vista has compatibility problems sometimes when it is executed in Windows 7. The program may also have been in early stages development that is why the error is showing.If the file is trully is fully Windows 7 Compatible, redownload the file and run it again. If the problem still occurs then I strongly recommend reporting the problem to the company. They would be able to help you in sorting out the problem.
Ornim,
