I have windows 7 64 bit installed and facing problem with Motion DV Studio LE. Problem is whenever I connect my Panasonic Camcorder with my PC, software does not identify it. When I was using Windows XP, I never faced any problem, but since my upgrade to Windows 7 I’m having this issue. Can anybody help me with Motion DV Studio LE windows 7 64 bit?
I see that when you connect your panasonic camcorder to your PC it is not being detected by Motion DV Studio LE. The possible solutions for your problem are:
1. Download the latest version of Motion DV Studio LE. Then install it on your computer and restart it. Now connect your camcorder and check whether it is being detected.
2. Download the panasonic software and install it on your computer. You can download it here http://panasonic.jp/support/global/cs/soft/download/motionDV60E_LE_1.html. This is an alternate solution. If your camcorder is not being detected by Motion DV Studio LE then you can try this software.
3. Another alternate is Windows Movie Maker which will be pre-installed in your PC.
Hope this information helps you.
