Help me with this issue Please
Hi Team ,
I recently bought an A50 cooler Corsair. I didn’t open it yet because I just want to make sure that it fits into my Ram before installing it. Any idea if it will fit because I am only using 2 DDR3 Ram on my P8P67 Pro B3 (Rev 3.1). I need help! Thanks
Best Answer by Luis Cotler
Answered By 0 points N/A #100779
The cooler is basically works to cool your processor. It hardly related to RAM. So you don’t need to think about your RAM. And the important thing is, is It compatible with your Processor or not. But here also you get a positive answer, because this cooler is compatible with all kinds of processors. So you got the right one for your PC. So go ahead and install it. It’s very simple to install you don’t need to be a professional to install it. Just open pc casing then open the lock of you old cooler and put this one on that place and lock it again. That’s all you have to do.
Answered By 20 points N/A #100781
Thank you Luis. I have installed it and its working pretty well. Thank again for taking time to answer my question.
