Help me how to remove 360safeguard?
How to remove 360safeguard? It was installed in my windows xp operating system. I don’t know how to uninstall a program using windows xp. Can you guide me in the process? I have to remove the application for I will install another software related to internet security program.
Waiting for your support, thank you.
Best Answer by Phillip Taylor
Answered By 0 points N/A #182057
Hi Alison Davy, I searched a solution that may help you solve your problem.
Removing or uninstalling program in Windows XP is quite easy. Just follow these easy steps:
1. Click on Start, and click control panel.
2. Locate Add or remove programs and click on it.
3. Browse the currently installed programs tab and then locate 360safeguard.
4. Click on 360safeguard, choose remove and click yes on confirming the removal.
Hope this information helps.
Answered By 0 points N/A #182058
You want to uninstall the 360safeguard you installed before.
The normal process for uninstalling a program is to go to control panel > Add or remove program > Select 360safeguard > Remove. This is the process. You might also have to remove the registry from it. Follow this link for further.
Answered By 0 points N/A #182059
Dear Allison Davy,
You can follow:
Follow the Antivirus 360 revealing and removal instructions below.
The most usual software elimination way is to remove 360safeguard by using "Add or Remove Programs" service. Though there may be concealed Antivirus 360 files, running processes and registries in your computer, so 360safeguard may reconstruct all other files after reboot.
