Help me download Core Audio Manager for Mac OS
A friend gave me his MacBook to install him some software's.
I am no expert in Mac and I though you could help me to download Core Audio Manager for Mac and a good movie player.
I would like some help as how to download and install Audio Manager first, and then the movie player.
Please help me as soon as possible.
Answered By -10 points N/A #172868
I would first like you to check if your java applet is up to date or not please download the latest version of the java from
http://www.java.com/en/ And then check if the problem persists or not secondly please check the speed of your connection If your connection I slow then there is a probability that the problem is caused due to this issue.
http://www.speedtest.net/‎
Last but not the least I would also recommend you to check the flash player version installed din you system
https://labs.adobe.com/downloads/flashplayer.html
If the auto update of the flash player is turned off then the previous version would not ne updated, So i recommend you to update the existing version.
If problem still persists then let me know.
Answered By 590495 points N/A #328331
On Mac, the core audio manager is the sound card driver or part of the sound card software. When you install the sound card driver, the audio manager should also be installed. This software component on Mac is the same with Realtek HD Audio Manager in Microsoft Windows which comes when you install the Realtek sound card driver.
Try updating your sound card driver. On your Macintosh, click on the Apple menu and select “Software Update.” On the next screen, see all the available updates for your operating system and install them particularly the sound card driver. If your existing sound card driver does not include an audio manager, updating or installing the updated version might include the audio manager if this is featured.
