Help on how to fix PES 6 crash on Windows 7
A few days ago, I encountered an issue with Pro Evolution Soccer 6.
While finishing the season, the game crashes and tells me that pes6.exe found a problem.
I thought I should try once more, reloaded the game but still the same error.
Reinstalled it, and nothing changes.
Can you tell me how to fix PES6 crash because I have searched every website there is, and found zero solutions.
Best Answer by Felipa Dolore
Answered By 0 points N/A #174012
This is caused by a Microsoft windows update KB917422 (MS06-051), this update might cause programs to stop unexpectedly with various errors. Uninstalling the update will fix the problem but may affect other installed programs; the best fix it to get another update from Microsoft which is able to resolve this.
Please download update from Microsoft and run it on your computer.
Answered By 20 points N/A #174014
PES6.exe is a program file of Pro Evolution Soccer 6 file from KONAMI. It is created by the software during its installation, so it is considered as a non-system process. Since most applications store data in the registry, it is possible that your registry encountered errors and invalid entries which affect your computer’s performance. You can try to fix this by downloading Advanced SystemCare Free tool that will help you clean and optimize your computer.
