Having a problem with Mac block Google image search.
Hi techyv,
Having a problem with mac block google image search. I am using my mac operating system in a dell computer desktop and was wondering why I can’t access google image searching for I have a fast and reliable internet connection. Can you please share with me on how to figure out all the website that has been block by my computer or browser? I am using chrome internet browser.
Hoping for your help.
Best Answer by lee hung
Answered By 0 points N/A #175057
Hi Angela,
I will help you to solve your problem. As you are using Mac operating system on a Dell computer, it should be a problem. Google Chrome is a good browser too. I think the problem of your Google Image search is your ISP. It may have blocked the Google service, so that you are unable to access it. Try accessing from other browsers. If no success, then call your ISP.
Answered By 10 points N/A #175058
Angela,
Thank you for your inquiry.  There are a few things you can do to try and get access to the Google Images.  First, check to make sure that JavaScript is enabled on your browser.  To do this in Chrome look in "Content Settings".  The next thing you could do is make sure your cache and cookies are cleaned out.  There might be a cookie that is saving the old format for Google, by cleaning these out you will help to eliminate that possibility.
