Having problem with a dangerous virus.
I am very sad after getting the following message with the title YOU WON! “Congratulations, you won a virus. Press “OK” to download” and there is no other button without ok.
This message is continuously showing! Am I really infected by virus?
Answered By 5 points N/A #128492
I think so. You are already infected with virus that’s why this message showing because that virus programmed like that for harming you that kind of problem. It does not matter whether you press OK button or not. You got that virus already inside your pc.
In order to solve this install a new latest antivirus. If you already have an antivirus in your pc then removes it quickly. It is not working at all. Remove it and install a different antivirus program and scan for that virus. I recommend use Kaspersky or Norton antivirus in this case.
You can also use online scan. It will be more effective.
