Having errors when running Instant c vb edition
Hey techyv,
I think I have a problem with instant c vb edition. My computers been slow lately and some of my settings in windows have been randomly changed. I am also getting crashes occasionally as well as the blue screen of death. Could a problem with instant c vb edition be the cause?
Answered By 5 points N/A #173471
Hi Katherine,
I don't think installing a C VB edition is not the problem. You have installed too much applications on your computer that is why when you installed the C VB Edition your computer did not take it anymore you can see it on the symptoms you mention such as your computer is being slow then some settings are changed so I recommend you to uninstall all applications that you don't use or not important to clean up your computer. Also scan your system because it's possible that your computer are being attacked by the viruses. I advise you to use the latest or trusted antivirus for your computer.
