Guide me on making tickets using business cards ?
Hi Experts,
I am having Photoshop on my desktop. I want to know steps on making tickets using business cards.
I need step by step guidelines to achieve this. I am having adobe Photoshop genuine version.
Zubin Lennon
Answered By 10 points N/A #132504
Making tickets using business cards in Photoshop I am very big task and takes time.
However I can provide you with certain links through which you can find step by step instructions to make tickets using business cards.
Please follow the link
For the video tutorial watch the below video.
Thank you.
Answered By 5 points N/A #132505
Hi Zubin Lennon,
I’m not exactly sure what you mean when you say “make tickets using business cards”. Are you planning to create a business card or design a ticket using Photoshop? Either way, let me help you with both and just select the solution that fits your need.
Here’s your guide in creating a business card:
1. Create a new file and set the following attributes.
a. Resolution: 300dpi
b. Color mode: CMYK
c. Dimension: 3.75×3.25
2. If you have an image you want to incorporate, go ahead and put it in. Just make sure that the resolution is also 300dpi.
3. Paste the image and use FREE TRANSFORM (T) to resize it.
4. Open TEXT TOOL (T). Select a good font and font size then type your business name or whatever you prefer.
5. If you have more information to add, change the font size to a smaller one.
6. It's time to put a border. Make a NEW LAYER (ctrl+shift+N) and select all (ctrl+A). Go to SELECT > MODIFY > BORDER and get a good amount of pixel. Set your foreground color to black.
7. Merge all the layers and save it on your documents folder.
Here are some images of business card you may draw inspiration from:
Select a good font and font size then type your business Business Card in Photoshop
For more guides, visit these websites:
Create a Print Ready Business Card in Photoshop.
Webmaster source com
For a complete guide on making a ticket using Photoshop, check out this website.
