Got an update error with N8 phone and Nokia Ovi Suite
I attempted to update my Nokia Ovi Suite with my N8 phone.
The update was almost finished but then I got this error ( see screenshot below).
Hmmm…this is weird since I experienced this for the first time and I have been doing this for a gazillion times already.
Any take on this?
Do you have a fix for this? I don’t think my phone is busted? Is it?
Reinstall device software
Cannot Install Software
There is a problem with installing software to your device.
For more details and advice, go to Nokia’s online support.
Error code: 12014
Answered By 0 points N/A #88138
Respected G Racho.
Your cell phone is not busted. It is true that you and many other people face this kind of problem from Ovi store and in applications.Most of the Nokia cell phones have their builtin Ovi Stores with much more applications and Software's.
Builtin means that you need not to update it as it will give the same output or applications for you. What should be updated is your Software's that your cell phone has. While performing the same result less activity again and again will give you nothing but the wastage of time  and small life of your cell phone. Things that are not supportive for your cell phone,must not be downloaded time and again.
It may  bust or burst your device some day.Dear you are urging your cell phone to install or update profitless thing.
I hope you got it.
Good luck.
