Got an error message using the Open Broadcaster Software
Hello experts,
I got an error message using the Open Broadcaster Software. The following error shows Entry Point Not Found. Have you any idea about this error? How can I fix it? Any help would be really appreciated. Thanks in advance.
could not be located in the dynamic link library OBSApi.dll
Open Broadcaster softwarev0.472b: OBS.exe- Entry Point Not Found
The procedure entry point
?InitAudioData@AudioSource@@IAEX_NIIIKO@Z could not be located in the dynamic link library OBSApi.dll.
Answered By 30 points N/A #174958
Hi there Vance R Robinson,
Open Broadcaster usually gives this error either when the installation is not completed successfully or there are some compatibility issues.
If you've run the software before, that would mean that the installation went fine, but if this is happening from the beginning, I would suggest you to try to reinstall the software first. Use the Add/Remove programs option in your Control panel for that, reboot your computer after the software is removed and do a fresh install.
If the error keeps occurring, it is the compatibility problem. Open Broadcaster requires your system to be up to date. Also, your DirectX drivers should be updated and you should have installed the latest available service packs for your OS. Once your system is all up to date and patched with service packs, the Open Broadcaster should work fine.
Best regards,
Drake Vivian
