Google Chrome won’t load and how to resolve it
Hi. I do not use Google Chrome very frequently. I have recently started using it. My Google Chrome won’t load and I have no idea why. How can the issue be solved? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #91286
Hi. To solve this issue that Google Chrome won’t load, you can first try uninstalling the application. You can uninstall the app from Windows by opening the control panel and then clicking on programs and features. Then click on uninstall after selecting Google Chrome app. Open the website of Chrome in IE or Safari or any other web browser for that matter. Next, select the button for downloading Chrome after which the installer needs to run. Then, sign into Chrome by opening the settings menu and clicking on sign in to Chrome. Enter all the Google account information.
Then, check if the issue has been resolved or not by opening Chrome again. Alternatively, you can close the tab which is not working as well by opening the task manager from more tools and then ending the process. Again check to see if Chrome is working fine or not.
Hope we helped.
