Google Chrome shows that its own web page is not available
Hi all,
This one’s an odd problem.
I am shown “This webpage is not available” error on my Google Chrome while it was loading
https://www.google.co.in/?gws_rd=ssl
How can this possibly happen?
It’s www.google.com. You get what I mean?
Please give your suggestion.
Best Answer by Carl Jack
Answered By 10 points N/A #144654
Hello Michael,
There could be several reasons as to why you are getting are error, and some of them are as follows;
  • You might not be connected to the internet, or you are connected the access speed may be too slow and therefore the web pages cannot be able to load successfully.
  • You will therefore need to check the network cables on your computer if you are on a LAN and make sure that they are plugged in correctly. If you are using wireless network connection, you will have to make sure that the place you are at right now has got a string signal to avoid slow internet connection problems.
  • If you have configured some proxy settings in the browser you may need to get rid of them for they may be the ones causing the issue.
  • You can also try using an alternative browser.
Carl
Answered By 0 points N/A #144655
Hello there Michael, upon reading your problem i found out that most of the cases having this problem starts when you are infected by a malware. I strongly suggest that you should scan your computer for Malware.
And also try different browser like safari or Mozilla. check if you are having the same problem.
If you get the same problem for sure you have problem with your proxy settings.
A malware and some Trojans can bypass the proxy settings of your computer.
Answered By 0 points N/A #144656
There are many reasons that your Chrome will show webpage not available page. Either its connection to the internet is blocked or the webpage you’re trying to visit isn’t accurate and so showing this error. Visit this Techyv page to get more information according to your problem.
Why Google Chrome keep saying webpage not available?
