Hello EveryOne,Most of the time I use IE6.0 . I also have Mozilla Firefox . Sometimes I open these two browser simultaneously. Problem is that all GIF images have the Mozilla Firefox logo affixed to them in Temp. Internet File and in My Documents, even though I used IE to access the GIF image. Any solution?
Hi James Fanklin ,
Your problem is not hard to be resolved you just have to follow my instruction.
What we have to do is install ActivX control of the internet when you complete download restart your PC then go to your browser settings and active the ActiveX control then download Flash player from here when you finish downloading restart your PC and open your navigator if you still have the same problem please install the last version of k lite 123 CODEC and your problem will be resolved the attached image is for k lite CODEC.
Hi
It seems that you want to change the Mozilla Firefox logo affixed to the GIF images. To do the required change, follow below instructions.
Right click in your GIF image >> select properties in the opening popup>>In the opened Properties window Go to General tab>>Click Change button>>In the Open with window select the program you want (EX: Internet Explorer) >> click Ok>>Apply>>OK
