joseph321
Posted on - 08/07/2011
Hello Guys, I have MS Office 2003 installed on my Computer.
Since few days I am experiencing an unknown error (mentioned below), whenever I copy some object from Excel and paste it in the Word.
An error occurred, and this feature is no longer functioning. Would you like to repair this feature now?
I click Yes. But after the repair process, it says that the server application is not available, etc., etc.
I also tried repairing the MS Office through Add/Remove Programs but of no avail.
Can someone please guide me over this issue? Should I uninstall Office 2003 and get Office 2007?
munju220
Getting error in MS word 2003?
This error can appear when objects with multi-level embedded are closed and the original document is clicked back.
When an original document is clicked, the embedded object is forced to close. However, any information about the embedded object within the other embedded object might not be updated before closing.
To prevent this problem, before you close any embedded objects, the original document shall not be clicked back simultaneously. Alternatively you shall close and update every embedded object individually from the inmost object.
Hope this could help.
You no need to install office 2007, if you are conferrable with windows 2003. But you need to uninstall this software and reinstall it. It will fix this issue.
