No of visitors who read this post: 683
Category: Windows 2003
Type: Question
Author: Lisa Cox
No votes yet
I am using Windows 2003 Server x64. I got an error message saying, “G200ED display driver has stopped working normally.” I got it the first time I tried to log in to the server. And the server takes too long to respond. What should I do? Any suggestion? Please help me I don’t know how to fix this problem. Thank you very much.
Comment viewing options
You should try updating the driver or alternatively re-installing the existing driver and see if that will solve the problem. In case the  driver update does not fix the problem, you will need to run a diagnostic on your RAM, The problem may be occurring because your RAM has problems, and you might just resolve the problem by testing and replacing the RAM.
The possible sign that you can use to see if the RAM has problems is if the screen is artifacting. You may also need to use the bootable Memtest at http://www.memtest.org/ to check the cause of the problem. In case you see red, then you will be required to replace the RAM.
-Clair Charles
