To Followed About How Do I Get To My Inbox In Gmail
Hi. I am a Gmail user. I have recently started using Gmail. I would like to know about the steps which need to be followed to know how do I get to my inbox in Gmail. Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #85073
Hi. The steps which need to be followed so as to learn how do I get to my inbox in Gmail are as follows-
1) First of all, you need to choose the inbox style
• In the address bar, type Gmail
• Click on the settings icon on the top right of the window
• Click on the inbox option
• In the inbox type, click on default, important first, unread first or priority inbox
• Modify the other settings such as show importance markers or steps to filter the mail
2) Then, you need to either add or remove the categories by-
• Type Gmail in the address bar of the browser to load it
• Then click on the option of configure inbox
• Select the options to be used next to the categories
• If you want starred messages to be shown in your primary tab of the inbox, then, click on it
• Select the save option
3) To move the messages, first open the Gmail account and then move messages from one tab to the other as needed
Hope we helped.
