Flash Player 10 Power PC
I am having big problems with Flash Player 10 Power PC issues. Only the earlier versions of the Adobe Flash Player 10 series work on the Mac non-Intel PPCs but these versions do not support many videos on Facebook, YouTube, etc. Can anyone suggest what I may do to make the latest versions of Flash work on my non-Intel PPC? Thanks.
Best Answer by Baker Mich
Answered By 0 points N/A #143328
Hello Ingrid,
For PPC edition (non-Intel) you need to download Flash Player 10.1 with size 81.7MB and save it to your Desktop, now you will find the Flash Player 10.1.102.62 version for the MAC platform you can download these versions from adobe site after this you will be able to access all videos from YouTube, Facebook etc
Answered By 5 points N/A #194850
Hi Ingridgonzalou,
Although I don’t understand why most updated versions would not work on Mac, however you can check the below link to see some nearby old one versions that works perfectly fine with the Mac.
http://www.oldapps.com/mac/
Official link that will help you get one from adobe is following.
If your Mac is with Power PC:
The latest support player version is 10.1.102.64
https://forums.adobe.com/thread/895134?tstart=0
If your Mac is with Intel and OS is 10.4 ~ 10.5:
The latest support player version is 10.3.183.11
Hope this helps.
Thanks
Baker
