Finding software to open eyes in a picture
I am editing a picture for my family where more than 5 members are met together. One of the family member has closed eyes. I want to make his eyes funny and opened. Which software is best for opening eyes in a picture?
Best Answer by Davidson Mudge
Answered By 0 points N/A #159716
I suggest you to use Adobe Photoshop in any CS version. It is the best software for opening eyes in a picture. Adobe Photoshop is a graphics editing software admired for its widespread features. It is also, presently, the foremost graphics editing software. It is an image formation and editor program. It can make any result or technique desired in illustrating or painting or design.
Best regards,
Heather marie
Answered By 0 points N/A #159717
Hi Bob,
You can do it via Photoshop by using the Lasso effect then use it in the round selection of the eye.
Then use the Layers Palette and make the opacity low after that move it to the position of the eyes. Sounds very complicated right?
I have found you a link that does this automatically, this website also has a lot of editing options.
You can click on the link here.
