Finding out without purchasing if a software’s full version works
I'm just wondering how exactly will I know that the full version of a software will be able to restore all the data as displayed in the demo version that I have tried?
I want to make sure before purchasing the full version.
Answered By 15 points N/A #109687
Hello Braydeni,
If you have the data that you created using the demo version stored on your computer, then you do not have to worry. When you install the full version you will be able to access the files, open them and use them using the full version just as you did while using the demo version.
It is only that you will get added functionality while using the full version and there will be no restrictions about something that you can do and others that you cannot while using the full version. So do not worry about losing anything.
Hope this helps.
Regards
Clair Charles
